ECU and sensor grounding points?
Re: ECU and sensor grounding points? (fmrprojects)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects »</TD></TR><TR><TD CLASS="quote">the ecu is the ground. most sensors are computer controlled grounds. </TD></TR></TABLE>
what he said. trust me he knows what hes talking about. except when it comes to playing dominos!
Re: ECU and sensor grounding points? (zclee.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zclee.com »</TD></TR><TR><TD CLASS="quote">Just curious if anyone knows where the major grounding points are for the ECU and sensors.</TD></TR></TABLE>
some of the 5v sensors are grounded on the thermostat housing. other grounds can be found in the dead end plugs on the newer cars, which trace back to chassis grounds inside the vehicle on the left or right side A-pillars or the ecu.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects »</TD></TR><TR><TD CLASS="quote">the ecu is the ground. most sensors are computer controlled grounds. </TD></TR></TABLE>thannks for your help. So the sensors ground at the ECU, and the ECU grounds near the passenger A pillar?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zclee.com »</TD></TR><TR><TD CLASS="quote">thannks for your help. So the sensors ground at the ECU, and the ECU grounds near the passenger A pillar?</TD></TR></TABLE>
yes, the wires come from the ecu, and the dead end plugs. then to chassis ground if i remember correctly.
tvrsir
07-10-2004 01:26 AM
