help
help
I got a 1999 civic hatchback with an b16a swap. When I drive the car just starts jerking. Something like 2 step but while driving. Also one other thing I replaced my intake manifold wit an obd0 engine the plugs are the same. So I just used that. Let me know if that is the problem
Re: help
As HALFKOREANBOY said, check your plugs for any wear. That might cause misfires.
Does the car jerk at a certain rpm if so check your tps since it might have a dead spot. This usually cause jerking at a certain rpm no matter what gear you are in. If this is the case and you have a multimeter you can check your tps for a dead spot.
