P28 ECU or P08??
P28 ECU or P08??
Hey guys i bought a del sol with a JDM D15B vtec swap in it. The guy had a P28 ecu in it. But i read online that the P08 is supposed to be for this engine. Will it really make a difference keeping the P28 that's already in it? Or should i just swap it out for a P08?
Re: P28 ECU or P08??
Good luck finding the P08 ecu. You should be running it though to run the motor properly. There are a few threads around the internet (saw one on desires.org recently) where people are making it work with other means.
Seagull Management
There's not much difference in the fuel and timing maps as far as I can tell. The biggest difference is that a P08 is meant to use a single wire unheated O2 sensor.
For what it's worth I ran that engine with a P28 for 5 years and it always ran perfectly and got excellent fuel mileage.
Seagull Management
You could go to pgmfi.org and find the .bin files and open them in crome and take a look at them though. Also, some of the differences you do find will be for differences in elevation and such between here and Japan.
GERBERBOII
03-17-2010 02:27 PM
CivicHP
05-11-2006 10:54 AM
trooper0641
09-13-2004 07:37 PM
