VTEC-e Engines
VTEC-e Engines
So I found a '92 Civic VX with a VTEC-e engine. Lots of body work done to fix rust and it appears to have actually been done right. 150k miles. Overall in very good shape. Buying for commuter car. Hope to get at least another 100k out of it.
Not a whole lot of info on these engines. Besides how they work and the MPG . Any notable common issues pertaining to this particular drive train?
Re: VTEC-e Engines
mine seeps some oil every now and then but runs like a champ. Clean out the intake and egr and kep the 13" VX wheels with 175 mm tires and youll have a nice commuter.
Check the O2 sensor, they are pretty expensive ($300) if it is bad but will pay for itself after you replace a bad one just based on fuel savings
I drive mine over 100 miles daily and have been getting high 40's to low 50's MPG consistently.
Buy a mpGuino to keep track of your mileage and help with your driving techniques. its tough to master lean burn
Re: VTEC-e Engines
Ecomodder.com will have a lot more on the D15Z1 engine.
Mine has 226k, doesn't leak or burn any oil. I run Motul 8100 Eco-negy 100% synthetic 0W-30 oil. I believe one common problem with the civic transmission is the input shaft bearing. Other than that, not much trouble.
Enjoy the car!
eH.
Enjoy the car!
eH.
Re: VTEC-e Engines
Its pretty exciting to be possibly joining the MPG Cult....
Out of curiosity, what did you guys pay for yours? I've noticed the market value is a bit higher than kbb for these things.
Re: VTEC-e Engines
Love the VX! I bought my 1994 VX in 2008 with 175k miles on it for $3k. That might be a bit high compared to today's prices, but it's paid for itself 2x over. People sometimes ask $4-5k, but deals can still be found.
I highly recommend an mpguino, which will help maximize your fuel economy. The VTEC-E can be a bit finicky to get running perfectly, but it's worth it. You just have to accept that you'll get passed by everyone on the road.
Lean burn can certainly be tricky to master, and the mpguino can help identify how much throttle/rpm you can apply before popping out of economy mode. The NTK 24300 O2 sensor is known to be a good replacement for OEM, and can generally be found for $100-200. Keep the tires inflated and a light right foot.
Re: VTEC-e Engines
My boy has a EK Civic HX which im sure its the vtec-e engine.... (d16y5 if I remember correctly)
but from what I know the engine is good, and saves alot of gas, if you do get that car with 150k miles I suggest that you do a tune up, oil change and change your timing belt and water pump when you first get it .... should easily last you another 100k miles as long as you treat it right and change the oil every 3k miles
you'll probably waste 200 in parts AT MOST if you do all that by yourself, but your car will be set
Re: VTEC-e Engines
The VX/HX O2 sensors are no longer that expensive. OEM brand sensors (NTK) are going for $150 now that all the tuners switched over to newer O2 sensors.
The VTEC-E engines are not that different from any other Honda engine. They have EGR just like many Accords do. The EGR system and intake manifold need to be cleaned out periodically. Other than that it's the standard coil/ignitor issues that plague all the other pre-distributorless ignition engines. The cat converter is on the exhaust manifold and is kinda pricey, so keep the engine tuned up so you don't destroy it. Exhausts from other models don't reach because of the different converter placement. The d15z1 came with a light weight flywheel so get it resurfaced rather than replaced. The d15z1 uses the same distributor as the D16z6 and no other will work.
Re: VTEC-e Engines
I'm not trying to justify my purchases through gas savings. The car is in excellent shape and I enjoy "working" it. A hobby.
eH.
Re: VTEC-e Engines
Cool guys thanks, some excellent info, keep it coming!
I'm a real grandpa when it comes to driving, I'm used to being passed. I'll look into the mpguino, although I fear if I have real time MPG it'll make it a competition for me to see how high I can get the MPG... I'll probably go mental. haha
According to the seller car has had a 'tune up', new brakes, tires, "high flow cat", new OEM Muffler, headers, clutch, throw out bearing and CV Drive shafts. Nothing about the timing belt or water pump, but I'm guessing it's near that time... Yayyyy!
I've seen some VX's go for ridiculous prices with twice the miles and half the shape! So I think this may be a dealio.
Re: VTEC-e Engines
As mentioned keep your tires over inflated, they are unique little cars that are actually quite fun to drive. You'll find yourself wanting to fill up to see what mileage you have been getting if you don't get a mpguino lol
My 1996 hx has 294k miles on the motor
Re: VTEC-e Engines
The timing belt and water pump shouldnt be so hard, youll be alright....
If you feel the price is right go for it.
kgib808
45
12-14-2015 11:00 AM
Don Napier
203
12-05-2004 02:52 PM
