How to adjust rear camber
Old 09-02-2014, 08:15 AM
Civic Racer X 7's Avatar
Default How to adjust rear camber
Racing a 94 hatch at a local dirt track
I really need to adjust my passenger side rear tire
To lean inward toward the car a good bit to help with cornering and tire/wheel roll
Best way to achieve this simply use washers for spacers?
Old 09-02-2014, 08:38 AM
DOHCtR-V's Avatar
Default Re: How to adjust rear camber
Invest in a ingalls camber kit.
They give you the option to adjust to your hearts desire.
Old 09-02-2014, 08:49 AM
Cool Cool Island Breezes. BOY-EE
B serious's Avatar
You can use washers for POSITIVE camber adjustment. You seem to want negative camber.
You need a camber kit if that's legal for your class.
If not, try using a stock 96-00 civic LCA on that side. Since they are longer, you'll get some neg camber. You'll need spacers for the shock fork. The fork is widely spaced. The bushing is narrow. You'll see.
Old 09-02-2014, 10:46 AM
Ok I looked at a couple kits
They adjust 4+ and -4 degrees
Trying to visualize how much that is leaning inward
Old 09-02-2014, 11:41 AM
B serious's Avatar
A lot.
Old 09-02-2014, 11:44 AM
B serious's Avatar
195/55/15 tires are 23.44" diameter.
Sin (4°) x 23.44 = 1.63" inward/outward at the top of the tire. Additonal to the neg camber created by lowering the car...if that's what they're advertising.
So...1.63" of horizontal movement.
Different diameter tire? Plug your diameter into that equation.
Old 09-02-2014, 04:54 PM
DOHCtR-V's Avatar
Most likely more than you need.
What do you think those "Hella Flush" fellas use to get that aggressive stance...
Old 09-03-2014, 04:10 AM
JDM_SOHC's Avatar
hella flush... hmmm...
Old 09-03-2014, 06:10 AM
DOHCtR-V's Avatar
jdmsir4dr
27
04-22-2010 11:23 AM
hatchetmansmybro
09-21-2006 04:15 AM
drumminforev
33
04-07-2006 02:02 PM
thehondabuddy
05-17-2003 01:44 PM
96 SOHC VTEC
01-05-2003 04:34 PM
Quick Reply: How to adjust rear camber
