oil on spark plugs
oil on spark plugs
As I was checking my spark plugs I noticed all the plugs have oil on them. I took off the valve cover and all the gaskets were fine which they should be since I put them on less than a year ago. The car is running fine so far with little issues. Do I need to buy a new gasket set? And what could of caused this issue? Thanks!
Re: oil on spark plugs
U don't say the motor but I am assuming it's the d15, if so up will have to pull the rocker arm assembly off (b sure to keep it all together) and there r 4 o-rings under it, 3 normal and one that looks like a figure 8. I don't believe u get them in a valve cover gasket set... hope that helps.
1 Post
Loves Tossing Salad
haha same here, how did you come to that conclusion? The picture? I snagged a couple of them for like 5 bucks, that's the easy part. Getting them off their existing resting place is the hard part
Because if so, they're less than a year old so I don't know why that would be the issue
1 Post
They usually come with a valve cover gasket set, but you can also buy them individually..
And sometimes the problem isn't the problem, the problem is your attitude about the problem..
just buy them and put them in and call it a day..
They're very fragile and have a spring inside that can bend and pop out very easily from installation and removal, hense giving you a leak into the spark plug cylinder..
That's the thing is it doesn't smoke at all and it runs fine. But how much are guides and seals
I just assumed it was, lots of people change the valve cover gasket plug hole gaskets and wonder y there still getting oil on the top of the plug... just sounded like that was the case. My mistake.
So it is the positive terminal, meaning the part where the coil wire plugs into, that has oil on it? If so, that's because of your valve cover seals not sealing properly and letting oil leak into the plug hole.
You either bought cheap parts or didn't torque the valve cover the correct way.
A word of advice, please at least know what you are trying to describe so other members don't have to figure it out for you. It's extremely frustrating to try to help someone who's not trying to help himself.
Loves Tossing Salad
Regardless of how old they are, sometimes taking the cover on and off even once can create a slit in the rubber. Happened to me when I didn't fit the cover on correctly and after that they're history. Pick up a valve cover gasket set from rock auto for like $15, should solve the problem.
