98 civic problem?
Old 08-28-2014, 12:16 PM
whistle pig's Avatar
Default 98 civic problem?
My daughter was driving her 98 civic and it overheated and started running poorly. When I got home it seemed to run fine but when it heated up I noticed the coolant fan did not run. I found the fuse had blown so I replaced it. The fan now runs but the car barely runs and the exhaust smells extremely rich.......Any ideas?
thanks.
Old 08-28-2014, 12:39 PM
mike_1212's Avatar
Default Re: 98 civic problem?
I would suggest you check compression... being it was ok untill overheating... do a compression test.. if you dont have thhe kit to do it you can borrow it from most any parts store.
Old 08-28-2014, 02:31 PM
I have 140- 150 on each cylinder, the car has 250,000 miles on it.
Would an O2 sensor cause it to run that bad?
Old 08-28-2014, 10:06 PM
mike_1212's Avatar
An 02 could cause it to run badly.... is it throwing any codes? CEL?
Old 08-29-2014, 12:30 AM
Retired Moderator
EsotericImage's Avatar
Check engine light = CEL
ekelly1
11
07-05-2015 10:48 AM
moabrubi
11-27-2013 04:48 AM
Soup Slayer
09-10-2013 01:35 AM
Quick Reply: 98 civic problem?
