98 Civic EX Cp Driver Door Electric vs Manual
Need to replace my 98 Civic driver door. It's electric. Unrepairable exterior damage, glass and interior fine. Manual doors are ceaper, can I retrofit a used manual door with my electric parts easily?
Re: 98 Civic EX Cp Driver Door Electric vs Manual (PMinMO)
if you want to change it to manually...you will need new/used non powered stuff:
door (since your is damage, but it doesnt matter if powered or not)
door panel
manually regulator (i hope that the correct terminology)
so i think it will be cheaper for you just to replace BACK to an EX door becuase you have most of the components already.
door panel
if you're asking if you can use a manual door (since they are cheaper) and turn it into power... yes you can... its just a matter of remembering where everything goes
Re: 98 Civic EX Cp Driver Door Electric vs Manual (SKiN)
"if you're asking if you can use a manual door (since they are cheaper) and turn it into power..."
Yes thats what I would like to do, all the electric parts on the existing door are fine.
Safety beam is bent via side collision, I doubt if I can straighten it. If I could I would repair that door.
Thought about pulling the door and using a jack, but one person said it would be extremely dificult.
tryin to fix that door would be some work, but it could be done. cost a lil bit of $$$ but it would be ALOT easier to just pickup a manual door and convert it over.
Re: (Eran)
The safety beam that ties the dorr hinges to the rear qtr panel is bent in about 2". The skin would be fixable, if I could straighten the beam.
LeonardDB
12-24-2006 12:31 PM
BIG_BOY
04-09-2006 03:26 PM
