Iacv wire colors?
Iacv wire colors?
Im finishing up my b16a sirII swap in my 97 hatch. Motor is obd1 car is obd2a and i am coverting it to odd1 using a p30 computer. My question is on the iacv the original plug has two wires, one blue/white stripe and one with yellow/black stripe. Now my harness i am using doesnt help me with the colors so i gave up tryin to figure out which wire is which on that so i decided to wire the iacv directly to the ecu. I know the ecu pins are a9 and a23(which is the ground). Now which of the two wires connects to what pin? Help will be greatly appreciated thanks.
1 Post
Re: Iacv wire colors? (97hatchb16)
what is the engine harness you're using from?an auto 96+ Civic?
are you still using the 2-wire IACV?if so,you know that A23 is the ground,so the other wire has to go to A9-right?
or,are you confused about which of the two wires is ground and which is signal?
Chris
Chris
Re: Iacv wire colors? (TeamNextGenChris)
yea im still gonna use the two wire iacv. i know which pin does what on the ecu, im just dont know which wire is ground and which one is the signal.
EK k kay
07-08-2006 08:25 PM
