Way to remove outer tie rod end WITHOUT ripping boot.
So I'm doing my inners soon, already got the parts, but my outers are perfect. No need to replace those. I don't want to get that pickle fork because it deforms the boot/rips it most of the time. And also I don't want to hit the threads from the bottom because I've already fucked up some threads in my old car.
Any other tool or tips?
Re: Way to remove outer tie rod end WITHOUT ripping boot. (fast95eg8)
Just bang the hell out of the metal that is on the knuckle that the threaded part goes through, it has worked every time for me.
Re: Way to remove outer tie rod end WITHOUT ripping boot. (97ShLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97ShLude »</TD></TR><TR><TD CLASS="quote">Just bang the hell out of the metal that is on the knuckle that the threaded part goes through, it has worked every time for me. </TD></TR></TABLE>
You dont have to beat on the stud to make it pop out of the knuckle.
Just take a soft faced rubber mallet and knock it from the bottom of the stud on the tie rod a couple times, and it should pop out.
Re: Way to remove outer tie rod end WITHOUT ripping boot. (.Red.EM2)
Cool guys, thanks. I stripped my old hatch's threads by banging it from the bottom with a big *** hammer. I'll try the mallet this time + banging it, which I did before too
you can use the "C" type removers if you look the bottom of the joint it has an indentation made just for this tool to fit there. It is like a screw and will pop them out easily and without screwing up the threads or the boot
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast95eg8 »</TD></TR><TR><TD CLASS="quote">...I don't want to get that pickle fork because it deforms the boot/rips it most of the time...
Any other tool or tips? </TD></TR></TABLE>
Re: (Minglor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Minglor »</TD></TR><TR><TD CLASS="quote">pickle bar</TD></TR></TABLE>
Re: (.Red.EM2)
You dont have to hit it on the stud, if you take a hammer and hit it really good on the knuckle where the bolt passes through, that will usually pop it out. Ive never had any problems on ball joints or tie rods when i just hit it really hard at about a 45 degree angle.
Re: (jadugartir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jadugartir »</TD></TR><TR><TD CLASS="quote">You dont have to hit it on the stud, if you take a hammer and hit it really good on the knuckle where the bolt passes through, that will usually pop it out. Ive never had any problems on ball joints or tie rods when i just hit it really hard at about a 45 degree angle.</TD></TR></TABLE>
Thank you, this is exactly what I said in the beginning of the thread. Do this.
Re: (97ShLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97ShLude »</TD></TR><TR><TD CLASS="quote">Thank you, this is exactly what I said in the beginning of the thread. Do this.</TD></TR></TABLE>
He is correct.
He is correct.
RyanStevenPhillips
10-07-2008 07:11 AM
Hanmin
28
03-09-2008 01:47 AM
kroze
01-02-2006 06:20 PM
david90
06-21-2004 11:10 PM
