Idle problems
Not to be confused with "THE MAN"
Idle problems
Ok this is the situation. 95 b16 sir bottomend/95 gsr head with the butterflys removed. ( I didn't remove them kid that bought the car from me did, I just got it back) It Idles at 2 grand then after driving will occasionaly drop to 1000. I have gone over all vac lines, replaced the Iac just incase, replaced gaskets and the TB. Might it be the fact that he removed the butterflys? Appreciate any insight
HT Order of Merit
Re: Idle problems (THE GUY)
Seems like a vaccum leak to me. You can check the FITV valve if you have one on the bottom of the throttle body. Make sure coolant is topped of and bled free of all air. If your SURE none of that is the case, adjust the idle screw on the TB. Thats what I do. :]
Re: Idle problems (JDM_Ej)
thanks bro. I did the brakleen thing, and it was a vac. leak between the two halfs of the manifold. ( tear in the gasket )
saikouEF8
06-15-2006 04:31 AM
iatetoes
08-08-2004 07:01 AM
