crap someone help me please :{ :{!!!! QUICK!
what am i holding? as you see, i dont know where the two ends connect.its the medal piece near my end fingers and that hse on the right with the clip..cant find the connects..is it supposed to just sit there like that.. and its HOT.
i have a d16y8
ey guys im trying ot take the old intake off and replace it with the stock one.but i ran into trouble!!! :{
im not sure which wire goes where and why there are 2 hoses unplugegd and im not sure if i accidentally did it or it was there already. help me out!
where do these two hoses end? do i replace the red hose and plug one into the engine and one into the intake ?
where does that hose on the far right with the clip go?
Modified by mechanicnoob at 6:56 PM 9/4/2006
Modified by mechanicnoob at 6:59 PM 9/4/2006
Modified by mechanicnoob at 7:41 PM 9/4/2006
i have a d16y8
Re: crap someone help me please :{ :{!!!! QUICK! (mechanicnoob)
one hole is for the IAT (intake air temp.) sensor and one goes to the valve cover.
The hose should go on the brass part on the intake tube and the IAT sensor should go to one of those holes. I'm not sure about the ohther hole though
Re: crap someone help me please :{ :{!!!! QUICK! (EM1_ChRiS)
i know that
i have the valve cover and the sensor covered.im not sure which one the third goes into because it doesnt fit
my main concern is also the two hoses that arent even plugged into bu is connected to other things.
Location: On a island w/ only a bridge to leave it, U.S.A
The second picture, the hose your holding is a coolant hose it should plung into the bottom of the intake manifold on the left there will be a bigger hose and im pretty sure in under or to the right of the big hose.
EDIT: and the red hose you can take off and put a small filter on the blocks nipple from like auto zone or something
Re: crap someone help me please :{ :{!!!! QUICK! (littleblue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by littleblue »</TD></TR><TR><TD CLASS="quote">The second picture, the hose your holding is a coolant hose it should plung into the bottom of the intake manifold on the left there will be a bigger hose and im pretty sure in under or to the right of the big hose.</TD></TR></TABLE>
where does the other end go ?
no u see in the second picture on the far right..that hose with the clip..i don tknow where that goes
that metal tube goes into the intake pipe, i remember on my old 1997 d16. Or wait, is there any coolant coming outta there? if not, it should plug into the intake pipe. So u got the red pipe for the brass part on the intake pipe, one hole for the IAT sensor, and that last hole for what u are holding on the first pic
put in a cold air intake and it will solve your problems, you wont have to worry about those hoses.
or next time you take something apart, remember where you disonnected it from.
I hope to god you don't connect the hose in the second picture to a coolent line on the throttle body, that hose goes to the intake arm for the fuel injector air injection (only the 99-00 have this).
the first picture with the clipped hose goes to the valve cover where the red hose is, for the PCV system
Cody
10-26-2004 04:09 PM
