what will be the best set up dohc vtec?
this is what i have and need help on what to use to make the best all motor performance with stock parts.
b16 head
gsr head
b16 cams
gsr cams
grs block with type r pistons
b16a2 stock block
ls tranny
gsr tranny!
eg hatchback
b16 head
gsr head
b16 cams
gsr cams
b16a2 stock block
ls tranny
gsr tranny!
eg hatchback
Ek Forever y0!
Re: what will be the best set up dohc vtec? (diggy)
gsr block with type-r pistons.
If you're boosting you might want to go with the b16 with oem pistons. rod/stroke ratio is slightly better.
b16 tranny will be the best choice of what you have,
Re: what will be the best set up dohc vtec? (ek forever guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy »</TD></TR><TR><TD CLASS="quote">
I've heard this before, so it's probably true...but in my head I want to say that the extra displacement of the b18 would be ideal
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by diggy »</TD></TR><TR><TD CLASS="quote">this is what i have and need help on what to use to make the best all motor performance with stock parts.
b16 head
gsr head
b16 cams
gsr cams
b16a2 stock block
ls tranny
gsr tranny!
eg hatchback</TD></TR></TABLE>
GSR Block with TR pistons
B16 head with GSR cams and valve train
GSR trans
sell the rest for for cash for more upgrades
b16 head
gsr head
b16 cams
gsr cams
b16a2 stock block
ls tranny
gsr tranny!
GSR trans
Re: what will be the best set up dohc vtec? (wicked_b16eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wicked_b16eg »</TD></TR><TR><TD CLASS="quote">
GSR trans
sell the rest for for cash for more upgrades </TD></TR></TABLE>
I'm just curious but why would you add the GSR cams to the B16 head? Aren't both heads about equal?
GSR trans
cute little bastard
b16 head
gsr head
b16 cams
gsr cams
b16a2 stock block
ls tranny
gsr tranny!
In my opinion, go with everything GSR. If these are the choices.
b16 head
gsr head
b16 cams
gsr cams
b16a2 stock block
ls tranny
gsr tranny!
Re: what will be the best set up dohc vtec? (SkoundrelUSA)
the gsr cams have slighter lift and duration then the b16 witch will add a slight increase during vtec and the gsr head has tighter intake chambers will yeild more torque in the lower rpms while the T/R pistons with unlease the power up top. this setup that i have just describe to you is know as the " Poor mans type R " this is one of the best bang for the buck N/A builds.
cute little bastard
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wicked_b16eg »</TD></TR><TR><TD CLASS="quote">the gsr cams have slighter lift and duration then the b16 witch will add a slight increase during vtec and the gsr head has tighter intake chambers will yeild more torque in the lower rpms while the T/R pistons with unlease the power up top. this setup that i have just describe to you is know as the " Poor mans type R " this is one of the best bang for the buck N/A builds. </TD></TR></TABLE>
lol can't be a poorman's R with a GSR head and shitty GSR cams
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA »</TD></TR><TR><TD CLASS="quote">
lol can't be a poorman's R with a GSR head and shitty GSR cams </TD></TR></TABLE>
At first i was like
But then i lol'ed :-D
At first i was like
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy »</TD></TR><TR><TD CLASS="quote">GSR cams will have a notable but slight increase in performance over b16 cams.</TD></TR></TABLE>
Good look on the info. Guess I need to learn a bit more on the B series.
Re: what will be the best set up dohc vtec? (blu eg22)
I did this same build except using a b16 block.
B16a block
CTR pistons
CTR crank
CTR rods
JDM 4-1 header
CTR crank pulley
9lb flywheel
GSR head
CTR cams
skunk2 70mm throtle body
skunk2 IM
skunk2 valve train
Stainless Steel valves
power from 2k all the way to 9800
and by far the best build for the money I ever did. Out of all the motors I had this one was the best.
B16a block
CTR pistons
CTR crank
CTR rods
JDM 4-1 header
CTR crank pulley
9lb flywheel
GSR head
CTR cams
skunk2 IM
skunk2 valve train
Cool Cool Island Breezes. BOY-EE
GSR trans
On an NA setup, the only good use of a GSR trans would be to throw it off a cliff.
Use a B16A trans if you're going NA.
Do you really have all that stuff laying around or is this a hypothetical question to make people start arguing?
GSR trans
Re: what will be the best set up dohc vtec? (B serious)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B serious »</TD></TR><TR><TD CLASS="quote">
X2
X2
Ek Forever y0!
Re: what will be the best set up dohc vtec? (ek4_b16a)
unless he gets to shifting into 5th gear in the 1/4, the b16 will be plenty fast for boost too guys.
He's be running ~low 12's/11's if he's shifting into 5th before trapping.
Let's see. All Motor.... GSR block/Type R pistons, GSR Head/Cams, GSR tranny. This is only if you're keeping just these parts. A GSR head will yield higher compression than a B16 head, roughly .2 of compression.
Find a B16 tranny though, and you're set.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blu eg22 »</TD></TR><TR><TD CLASS="quote">
I'm just curious but why would you add the GSR cams to the B16 head? Aren't both heads about equal?</TD></TR></TABLE>
See above.
See above.
Re: what will be the best set up dohc vtec? (black_EM1)
your all telling him to use a B16 trans when the OP says that he wants to know what to use with what he has....
Need to pay attention to details.
And a gsr trans for 1st 2nd 3rd (the gears for 1/4) are pretty close to same.
further more the gsr head would yeild higher compression then the b16 but the main thing is that the smaller intake chambers would make better torque down low were the b16 head wouldn't but the Type R pistons would bring the high compression up top and make the HP needed in the upper RPM band.
I would have to agree with whomever stated it above:
gsr block w/itr's
b16 head
gsr cams
gsr trans.
poor-mans type r= fun for everyone!!
Throw in a mugen/spoon 2 layer h/gskt, and a chipped p28 for spice!! haha
Id recommend getting rid of the rest of your stuff, and picking up some jspec itr/ctr cams, and a b16 trans. Just my .02
gsr block w/itr's
b16 head
gsr cams
gsr trans.
Re: (tecMNSTR719)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tecMNSTR719 »</TD></TR><TR><TD CLASS="quote">I would have to agree with whomever stated it above:
gsr block w/itr's
b16 head
gsr cams
gsr trans.
Id recommend getting rid of the rest of your stuff, and picking up some jspec itr/ctr cams, and a b16 trans. Just my .02</TD></TR></TABLE>
That would be me...
The CTR intake cam is the only one that is different from the rest.. if you want a nice set of OEM cams get ITR.. other wise pick up some aftermarket cams.
If you want to get a chipped ecu, get a blank E-prom and have a tunner write the program for you setup.
And for trans find a lsd trans.. this will make sure all you power gets put down when you launch.
gsr block w/itr's
b16 head
gsr cams
gsr trans.
That would be me...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wicked_b16eg »</TD></TR><TR><TD CLASS="quote">your all telling him to use a B16 trans when the OP says that he wants to know what to use with what he has....
further more the gsr head would yeild higher compression then the b16 but the main thing is that the smaller intake chambers would make better torque down low were the b16 head wouldn't but the Type R pistons would bring the high compression up top and make the HP needed in the upper RPM band. </TD></TR></TABLE>
It's funny how you re-write my post in your own words. Really. And for the tranny, 1st is the same. 2nd is slightly longer, and so is 3rd.
And for the last time:
98-01 ITR cams are the same as all CTR cams. 96-97 ITR cams have something like 3* less duration or something.
Lesson for everyone because I'm feeling nice.
Why does a GSR head yield higher compression than a B16 head? Is it because of the square intake ports?
No, its because of the smaller Combustion Chamber Volume(cc). The B16 head has a (cc) of 42.70cc, whereas the GSR head has a (cc) of 41.60. The GSR head is also more resistant to detonation.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black_EM1 »</TD></TR><TR><TD CLASS="quote">
No, its because of the smaller Combustion Chamber Volume(cc). The B16 head has a (cc) of 42.70cc, whereas the GSR head has a (cc) of 41.60. The GSR head is also more resistant to detonation.</TD></TR></TABLE>
It's funny that your say that I rewrite what you wrote when you just did the same thing on the GSR head subject... lol. I'm not going to sit and throw pissing match like you. I don't need a lesson on this topic.
On the trans subject I said there basicaly the same... You said there slightly different.. Am I the only one catching this here...You just agreed with me on the subject of them basicaly being the same you just wrote it as if you were trying to prove me wrong. All you did here is make your self look like an *** hat. "There slightly different".. In other words there basically the same.
You my friend need the lesson....
It's funny that your say that I rewrite what you wrote when you just did the same thing on the GSR head subject... lol. I'm not going to sit and throw pissing match like you. I don't need a lesson on this topic.</TD></TR></TABLE>
I added onto my original post with some little known information that wasn't written anywhere. Henceforth the lesson "question", and the subsequent answer.
It just amazes me how people amend others answers but never care to add anything to it. Looking back on your other post, you needed to be corrected. If you can't find it your self, oh smart one, you have a problem. I'll give you a hint. "Intake Ports".
/arguement
Actually I agreed 100% with you, again I expanded on what was there. I wasn't trying to prove you wrong in the slighest.
You my friend need the lesson....</TD></TR></TABLE>
Trust me, there's not a damn thing I could learn from you.
/arguement
