D15B valve cover gasket...
1 Post
Ok, so I got my THIRD one today and again WRONGGGG..!!!! I've tried two different D16Z6 ones and a D15B7 and neither worked both were about an inch and a half to long... I could have swore that the z6 gasket was it but I even tried using different brand names and had no luck... I've searched and found others have had this issue but the only answer they ever get is USE A Z6 GASKET, and my argument is that i've tried several and none work... Anyone know a place to get specific gaskets...?? Kinda gay cuz d15b head an z6 heads are identical..
Yeah, just buy the gasket kit for the 1.6. That's what I did for my d15b - "marquisdee1018" from thread https://honda-tech.com/zerothread/2043792
Re: (z6hatchboy)
You got a z6 gasket and it didn't work? The d15b is a 1.5 block with a regular d16z6 head valve cover is interchangeable with y8 and z6 either of those gaskets will work.
1 Post
Re: (ejoner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ejoner »</TD></TR><TR><TD CLASS="quote">You got a z6 gasket and it didn't work? The d15b is a 1.5 block with a regular d16z6 head valve cover is interchangeable with y8 and z6 either of those gaskets will work.</TD></TR></TABLE>
yup... tried 2 different brands even an didnt work, both to long... i thought it was impossible but like stated, i've searched an found others had this issue... WTF y0...!! nothing like leakin oil out the back of the valve cover even with rtv sealant..
Location: Dont You Just Love Lynn Cops, Boston MA, USMA
I was fixing some one car, few years back.
Went to autozone and bought gasket. Didnt fit so went back like 3 times. I was really pissed of, so i bought a universal gasket for honda/ forgot. End up being alittle bit longer, so I snipped the gasket and use some gasket sealer. Well dont do what i did, but if you had no choice, cut it. What a half *** job i did.
1 Post
Re: (phyzJunkieCivic)
i thought about that actually but then was thinkin theres prolly a reason why those things are so thick to fit in that groove, i doubt it holds up as well as a stock gasket but then again theres not much pressure in there so who knows... might be my last resort..
My buddy came over to my house. I told him to pop the hood just to make sure there wasnt any leaks. Cant believe it 3 1/2 years with no leak, not even a oil stain around the gasket.
My grammar was so bad,I had to edit this post twice
Are you talking about the sealent? I think i used something that look somewhat oranged, bought it from walmart. Maybe it was RTV sealent?
1 Post
yeah Ill probably use the orange as well, just thought I heard something like using the black is better cuz it blocks oil or something but dunno if anyone can verify that...
Re: (JDM_SOHC)
I have a d15b and i wanted to replace valve cover gasket so i bought one for the d16z6 and i didn't have a problem with it. I used the felpro gasket set
ej1 rep
12-22-2011 09:21 AM
Mattmob
11-08-2006 04:53 PM
1991civicsi
03-24-2006 08:03 PM
