Installing Spark Plug Seals
Old 12-22-2007, 06:42 PM
EK_B's Avatar
Default Installing Spark Plug Seals
So do I just take off the valve cover and pull the old ones off and just plug in the new ones? Easy as that?
Or is there a certain way to install them?
Any other recommendations? Thanks.
Old 12-22-2007, 06:43 PM
z6hatchboy's Avatar
Its as easy as that
Old 12-22-2007, 06:58 PM
phyzJunkieCivic's Avatar
Location: Dont You Just Love Lynn Cops, Boston MA, USMA
Make sure all 4 stick to the valve cover, when putting it back on the head.
Old 12-22-2007, 07:03 PM
z6hatchboy's Avatar
^x2!
Old 12-22-2007, 07:33 PM
crazyguy's Avatar
Default Re: (z6hatchboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by z6hatchboy &raquo;</TD></TR><TR><TD CLASS="quote">^x2!</TD></TR></TABLE>
X3
Old 12-22-2007, 10:33 PM
EK_B's Avatar
So do I have to put anything on it to bond them to the valve cover?
Old 12-22-2007, 10:36 PM
Banned
yoffer's Avatar
You shouldnt. Just wipe inside where the seal goes after you take out the old ones and set the new ones in.
Old 12-22-2007, 10:37 PM
HT White Ops
Eran's Avatar
The easiest way I've found is to remove the old ones with needle nose pliers by twisting (till it curls) and then pull.
When installing the new ones, I use urea grease around the edges, and pound them into place with a rubber mallet.
Old 12-23-2007, 12:00 PM
Pound them into place? Your not useing over size gasket are you? J/K man.
vladvv
Honda CR-V & Element
09-20-2012 08:20 PM
brucepick
01-22-2011 08:51 PM
Ritchie
12
12-21-2006 07:29 PM
themorphious
06-03-2006 12:14 PM
integlspwr01
12
10-13-2003 11:16 PM
Quick Reply: Installing Spark Plug Seals
