Engine Overspeeding!!!! Lend me your ears!!
okay so Im leaving base my engine starting tapping out on the rev limiter with no thorttle. SO I shut it down when I started troubleshooting. I noticed a black plastic peice on the firewall was snapped. So I held it in place and my friend lightly revved it and it was back to normal but I have to replace this peice does anybody know what its called or how much this peice is???
YEAH!!! anything smaller though I tried using a small hose clamp but that didn't work. I guess vice grips will work..'
I tried using duct tape..it didn't work
you know the saying if you cant duct it F%$# it
Re: (GSE980)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSE980 »</TD></TR><TR><TD CLASS="quote">YEAH!!! anything smaller though I tried using a small hose clamp but that didn't work. I guess vice grips will work..'
you know the saying if you cant duct it F%$# it</TD></TR></TABLE>
Ya but that cable wants to move back and forth when u step on it so im thinking Vice Grips would work but dont clamp down too hard u just want to hold the outside cable not the cable inside
no the cable goes through a housing which plugs into the firewall this snapped making the cable slack which is making it rev high and not de accelerating....but if i clamp the housing the cable will still be able to move and will hold it at the right angle for no slack....I was also thinking about tightneing the bracket so tight that there is no slack in the calee but I odnt know if this would work or would it idle right I guess ill try the vice grips
Re: (GSE980)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSE980 »</TD></TR><TR><TD CLASS="quote">no the cable goes through a housing which plugs into the firewall this snapped making the cable slack which is making it rev high and not de accelerating....but if i clamp the housing the cable will still be able to move and will hold it at the right angle for no slack....I was also thinking about tightneing the bracket so tight that there is no slack in the calee but I odnt know if this would work or would it idle right I guess ill try the vice grips</TD></TR></TABLE>
Let me know how it works
I tried the vice grips the plastic piece is not the problem..
the wire is birdcaging inside the rubber sheath not allowing it to drop back down to idle
Its a GSR I went to the junk yard and picked one up for 30 bucks and also got a one piece black headlights also...then a 00 GSR rolls in theft recovery hooked up guy is elling it to me for 2500....YAY
philosofy1
07-21-2005 03:37 PM
