Radiator question
Radiator question
So when i was pulling my motor the other day i cracked the upper neck on the radiator (dx eg, 5 spd.) I have a radiator from my buddies 95 ex auto, and i am thinking its dual-core because of the two small lines on the bottom for the trans. So when i put this in and fill it up, will it all leak out of the two bottom lines, or do they need plugged? Thanks.
if im not mistaken i believe that radiator is like you said auto, thats for the tranny cooler. It shouldnt leak. I did a auto to manual swap on my Escort and used the auto tranny. I just unhooked the lines and no leaks. The tranny fluid must flow around the fins and stuff. You should be fine.
Re: Radiator question (z6hatchboy)
It will not leak, that is a seperate brass coolant tank located inside the endcap of radiator for trans fluid. No need to cap them off.
Charlie Moua
04-26-2023 02:47 PM
gold_pwr_r4ng3r
Honda Civic (2001 - 2005)
04-10-2012 11:32 AM
6shootahorsenamedtrigga
06-01-2007 04:09 PM
