Stripped tranny side mount studs???
When removing the bracket on the passenger side mount that hold it to the tranny, I found them to be very hard to remove. Then when reinstalling the nuts they stripped the 2 stud posts, the nuts are barely holding on. Fortunately there is the one bolt that holds the bracket to the tranny. How hard do you think it will be to replace these studs in the tranny???
Theyre just studs - Remove them and replace. Lefty-loosey.
If you cant thread 2 nuts on (lock-nut removal method) you will have to use some vice grips.
When you put new ones on, use the lock nut method to get the proper tq
stehigs321
12-21-2007 09:49 PM
