Shimming bad while at high speed
i just replaced the front brake pads and rotors in my 95 civic dx. and it still shakes pretty bad when i depress the brakes at high speed. not so much at low speeds.... thanks
Re: Shimming bad while at high speed (V-8 who)
Check your tires to make sure thay are balanced.
I thought I had everything wrong with mind till I did that.
Wheel Bearings going bad jack your car up and see if u can move the wheels back and forth with the wheel locked
Re: Shimming bad while at high speed (cln92eg)
could be wheel bearing.i know you said you had new rotors it could be a bad rotor on it.i work in a shop we get brand new rotors that are bad right from the parts store.or a bad tire or the balance on the tires.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cln92eg »</TD></TR><TR><TD CLASS="quote">Wheel Bearings going bad jack your car up and see if u can move the wheels back and forth with the wheel locked </TD></TR></TABLE>
You would hear that though even at low speeds. I've been through that too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cln92eg »</TD></TR><TR><TD CLASS="quote">Ya that is true but if his car doesnt shake when hes not on the brakes then why would it be tires </TD></TR></TABLE>
If a steel belt shifts inside of the tire it can do that, it can also "egg" at higher speeds.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cln92eg »</TD></TR><TR><TD CLASS="quote">Dam well never had that problem yet good to know tho </TD></TR></TABLE>
Yeah, it really threw me for a loop too. I thought I had a bent rim or a bent half-shaft or something.
