need help
need help
my buddy just picked up a 95 civic with a 2000ls motor in it and when we whent to start it today it didnt start or anything, all the electronics worked, but we had no spark at all and when we turned the key we got a whinny sound any ideas that can help us out please
Re: need help (cln92eg)
so change the starter out? also the ls motor has a gsr tranny and also noticed that on the bottum next to the oil pan its either the fly wheel or the tranny is exposed or should it be covered up?
Re: need help (LifeMage)
worst case scenario would be a broken Tbelt... so pull off the distributor cap and try starting it, if the rotor turns your ok, if not well... not so ok.
Also like dud said the start might not be engaging the flywheel, try bumping the flywheel by turning the crank or push start the car.
I would try the starter and see what that does make sure its hitting the flywheel teeth or not and that plate you're talking about is a factory thing most ppl that do trannys swaps get lazy and dont put the plate back but then again I dont know if the plates are different for each tranny or not so but u dont have to have it there is nice to have when rocks are around
I would go to the dealer i will find out how much it is hold on i work at honda so i can get prices so its a LS with GSR Tranny
yeah ls motor with a gsr tranny he picked the car up for 3100 so he couldnt beat the deal so yeah we've been trying to fix it up and get it running properly (ie get rid of the check engine fix the engine up and than get it running smoth)
U guys looked at the How to Read Codes https://honda-tech.com/zerothread/1901557
yeah were also having a buddy come over who knows this **** better than i do(hes 23 or so and my and my buddy that owns the car are 18 and both are getting into the tuning scene, so yeah ) turned to here for help and hopefully what you said will point us properly.
ya cause thats what it sounds like and u said your buddy was driving so I dont think the timing belt would brake right once he got in the driveway so unless it was on it hard and it stopped workin then had it towed home idk its your timing belt at all
it worked properly. we towed it home on a dolly (about an hour and a half drive.) backed it off the dolly and also he pulled it out earlyer today before i came over to wash the car off and such
thats weird ya just check your timing belt and ya starter see if its loose or not but i cant see why it would just do that
Re: (LifeMage)
it could be the starter, could also be a chipped flywheel. if there are enough broken teeth on the flywheel there would be a dead spot where the starter doesnt touch anything. Pull the inspection plate and turn the motor over one full revolution while looking at the flywheel.
