alignment after suspension what do i ask for
Hey i am about to finish putting in my Tien ss's and i dropped it 2 inches, what do i ask for when i go to the alignment shop, i did LCA's to, is it possible to get a four way alignment, i dont know what to ask for, its my first time doing suspension on a car, sorry, i am a super noob on this subject so please try not to flame, and please dont tell me that my selection was bad, because i did a lot of research on it so I decided that is what i wanted
Re: alignment after suspension what do i ask for (z6hatchboy)
Well, ideally you need to locate an alignment shop with a good reputation that you can trust before you do anything.
Then simply explain what you have replaced and have them check the alignment completely.
Afterwards, keep a very close eye on your tires for signs of uneven or improper wear, particularly on the outer shoulders. Watch for excessive wear, cupping, etc.
Re: (Historyg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Historyg »</TD></TR><TR><TD CLASS="quote">so a four wheel then check for a while for any thread lose on the tires</TD></TR></TABLE>
Something like this:
Hopefully you'll notice way before it got that bad. Just keep an eye on it, and if it's still even and good by the next oil change... you can stop watching it.
one more questions guys thanks for all the help, but should i do the washer trick in the back, and i got the diy for it but i am not sure about the nuts is it a 10x1.25 thread, if it is i will go and get it and do it, because i was up all last night changing the ISB on my tranny and only did the front suspension, and then i assed out, because i was way to tried, so before i do the back i could do the washer trick, if its not necessary i will just skip it, thanks again guys
why would you do the washer trick if you haven't done the suspension in the back yet?
how about lower it and see if its necessary, most of the time the rear is fine unless you're one of those people who insist on having your car too low.
taimysho0
15
10-11-2023 09:49 PM
TEG98
04-06-2003 08:33 AM
