LS OR LS VTEC is there much difference???
I know there's a difference but I wanted to know how much of a difference it is for a daily driver turbo setup?? Any advice would be nice.
Re: LS OR LS VTEC is there much difference??? (cln92eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cln92eg »</TD></TR><TR><TD CLASS="quote">Ls can hold more boost stock compared to a LS/V </TD></TR></TABLE>
lsv isnt stock
lsv isnt stock
Re: LS OR LS VTEC is there much difference??? (HondaTeKnology)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaTeKnology »</TD></TR><TR><TD CLASS="quote">I know there's a difference but I wanted to know how much of a difference it is for a daily driver turbo setup?? Any advice would be nice.</TD></TR></TABLE>
If there wasn't much difference between LS and LSvtec, why would people do it in the first place?
Just the fact that you are asking which is better for turbo makes me assume you lack the technical expertise required to even build a proper LSvtec...Stick with the LS.
Re: LS OR LS VTEC is there much difference??? (nix94delsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nix94delsol »</TD></TR><TR><TD CLASS="quote">
lsv isnt stock </TD></TR></TABLE>
I didnt state any where that LS/V was stock I guess I have to be more detail
A Stock Ls Can hold more boost then a Modified Ls/V
A Stock Ls Can hold more boost then a Modified Ls/V </TD></TR></TABLE>
A stock LS can hold about 250 whp reliably...but you can modify an LSvtec to hold much more than that.
So unfortunately, your statement is just wrong.
Re: LS OR LS VTEC is there much difference??? (andoxviii)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andoxviii »</TD></TR><TR><TD CLASS="quote">
So unfortunately, your statement is just wrong.</TD></TR></TABLE>
Ok well key Word MODIFY if u slap a Ls/V together Stock and LS, the Ls would be a better DD
Re: LS OR LS VTEC is there much difference??? (h-duced)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h-duced »</TD></TR><TR><TD CLASS="quote">H22 </TD></TR></TABLE>
thank you
thank you
Ok well key Word MODIFY if u slap a Ls/V together Stock and LS, the Ls would be a better DD</TD></TR></TABLE>
do you realize what goes into a decent ls-vtec?
its definitely nothing you can just "slap together"
My answer is more on cost issues, for the cost to make a reliable ls/v you could either boost your ls, do a b-series vtec swap or h22, or just do the bolt on's to your ls. It takes many people around 4-5k to do their ls/v builds (which probably includes boost?).
For 350hp, i think their would be issues on the stock rods and such of a ls, i think you should swap for a b16 build it mildly (rods, pistons), boost it, injectors, and get a good tune.
NooB
Readin owns joo
He means a stock ls can hold boost safer then a ls/vtec that has no mods other then the turbo.
Readin owns joo
Re: (z6hatchboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by z6hatchboy »</TD></TR><TR><TD CLASS="quote">For 350hp, i think their would be issues on the stock rods and such of a ls, i think you should swap for a b16 build it mildly (rods, pistons), boost it, injectors, and get a good tune.</TD></TR></TABLE>
Why is a b16 better, because it has VTEC?
I love how people think vtec is better than displacement. Besides, the b18b can hold more boost in stock form than a b16a. And if you are going to upgrade the internals, I would still rather an upgraded LS...
I would take an LS over a b16 anyday. It costs way less, its better on gas because of its longer gearing, its hold more boost reliably, it has more displacement, it is more readily available in USDM form...the list goes on and on...
Re: LS OR LS VTEC is there much difference??? (IT'S ME DAVID)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IT’S ME DAVID »</TD></TR><TR><TD CLASS="quote">
Readin owns joo
He means a stock ls can hold boost safer then a ls/vtec that has no mods other then the turbo.</TD></TR></TABLE>
Thank u some one understands what i was trying to say
Readin owns joo
I would take an LS over a b16 anyday. It costs way less, its better on gas because of its longer gearing, its hold more boost reliably, it has more displacement, it is more readily available in USDM form...the list goes on and on...</TD></TR></TABLE>
IMHO vtec was made for boost. (not literally) i have a b18a in my coupe and was gonna do a LS/V but for the money i would waste on a LS/V i could just buy a b16a block and make life alot easier. LS/V is only as good as the person building it
Re: (andoxviii)
Who here said vtec was better than displacment, and since when was the majority or displacement in the dome of the head ? The question in partly about ls vs. ls/vtec, and that was my opinio. If you want to get smart about it, then get a b18c5 head because of the partial oe porting for better flow. And yes a ls is more readily available in usdm or any for for that matter, when did honda startin making ls/vtec oe, hmm? Also, i said nothing about using a b16 tranny, just a head.
Re: LS OR LS VTEC is there much difference??? (jdm-yoda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm-yoda »</TD></TR><TR><TD CLASS="quote">
LS/V is only as good as the person building it</TD></TR></TABLE>
Very true
Very true
Re: (z6hatchboy)
Who here said vtec was better than displacment, and since when was the majority or displacement in the dome of the head ? The question in partly about ls vs. ls/vtec, and that was my opinio. If you want to get smart about it, then get a b18c5 head because of the partial oe porting for better flow. And yes a ls is more readily available in usdm or any for for that matter, when did honda startin making ls/vtec oe, hmm? Also, i said nothing about using a b16 tranny, just a head.</TD></TR></TABLE>
Right. So it's a good thing I said "LS" and not "LS-VTEC". I am telling you that LS > b16a, and I listed the reasons for my opinion. That's it.
Come on guys... lets stay on track with this. The OP is looking for 350hp on either an LS motor or an LSvtec ... H22, B16, K20, and B18c (P72/73) are not choices. You are going to turbo so why not go the route that is going to cost you less and give you more reliability in the end? Both will be built, but the LS is going to be the cheaper route. My vote is for the B18b1...
...I am telling you that LS > b16a, and I listed the reasons for my opinion. That's it. </TD></TR></TABLE>
^^^ So true... numerous people have had a stock B18b/b1 w/ a B16 trans and have left the B16 behind.
