would this cut though the floor?
4 SPEED ROTARY TOOL KIT
Versatile tool is ideal for shaping, sanding, deburring, grinding and polishing. Effortlessly removes rust on metals, plastic and wood. Thirty piece kit includes the most popular accessories packed neatly in a blow mold case. Double insulated.
Motor: 120V, 60 Hz
Direct drive
4 step speeds: 6500, 10700, 14000 and 22000 RPM
Collet sizes: 1/8'' and 3/32'' diameter
Motor: 120V, 60 Hz
Direct drive
no, there is no way you can get through the floor with that dremel, its made for soft materials, read the manual that came with it.
get something like this. its called disk grinder and you can find a cheap one for about 60 bucks. and the blade will go from $5-$10
Re: (burgandybeast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by burgandybeast »</TD></TR><TR><TD CLASS="quote">Just curious...Why cuttin the floor?</TD></TR></TABLE>
Weight reduction. He is removing the useless areas
Re: (Doostur)
Uhhhh...A honda is a unibody car. You cut out the floor your cutting the frame.
Not a smart idea...Especially if its a DD. Just my 2¢ o and btw.
If you let anyone ride with you in a hackjobbed car..
And you hurt/kill them..Your gonna be spending some cheese or doing some jail time.
H-T White Ops
Re: (burgandybeast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by burgandybeast »</TD></TR><TR><TD CLASS="quote">Uhhhh...A honda is a unibody car. You cut out the floor your cutting the frame.
And you hurt/kill them..Your gonna be spending some cheese or doing some jail time. </TD></TR></TABLE>
He's not cutting out all the useless floor... That was a joke.
Re: (phyzJunkieCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phyzJunkieCivic »</TD></TR><TR><TD CLASS="quote">A grinder will be great, if you like fireworks.
I rather use a saw zaw instead. Is it spelled "saw zaw"?</TD></TR></TABLE>
i thought it was called a sawz-all, which is what i would use if i were to cut a floor
Ek Forever y0!
Re: (burgandybeast)
Not a smart idea...</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by burgandybeast »</TD></TR><TR><TD CLASS="quote">someone please explain to me why frame weakness for weight reduction is cool..
>.< this thread is making my nuts hurt. </TD></TR></TABLE>
Someone please explain to me why you two can't expletiveing read.
Ek Forever y0!
Re: (burgandybeast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by burgandybeast »</TD></TR><TR><TD CLASS="quote">he said he wasnt cutting out "ALL" the useless floor..
He never said it was a joke.</TD></TR></TABLE>
Re: (burgandybeast)
I'm just saying a few extra lbs isnt worth risking your life.
After being pretty much t-boned from the passenger side
you kind of worry about stuff like that especially at high speeds.
H-T White Ops
Re: (burgandybeast)
Maybe, just maybe, he's not meaning to cut out the entire floor. Maybe he's doing an auto to manual swap. Maybe he just means to put a hole in the floor for drainage.
Why in hell do you jump to the conclusion that he's going to start cutting out massive chunks of his floor?
Re: (burgandybeast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_CRX_PLEASE »</TD></TR><TR><TD CLASS="quote">im doing auto to manual conversion</TD></TR></TABLE>
Dropped90Integra
02-13-2005 06:27 PM
