No power, good fuses?
I hooked my battery up backwards and lost all power.
Nothing happens with the key in. I checked the 80 amp main battery fuse and it's fine.
What else could it be?
Re: No power, good fuses?
That fuse will blow without exception if you connect the battery backwards.
Connect the battery properly, and use a voltmeter to find out where the voltage is being lost. Especially check both sides of each fuse.
bennjamin@ozhonda.com
09-04-2006 05:20 AM
