help on window seals and trim
hey, I need help on couple things for my car (93 Civic LX). I have basically fully restored this car but I need a couple things still.
# 1 door pillar trim
# 2 window seal
# 3 ???
- rear drivers side door pillar trim. It appears that they have discontinued it OEM so I have to go aftermarket ebay or a faded junk yard one. Im having trouble finding the appropriate clips for it.
- front driver side window seal. Im not always the best at looking at parts diagrams but im thinking its called the sub seal part # 72365-SR4-A03?? im mostly tired of hearing the wind hitting it and how it gets bunched up when you roll the window up.
- im not even sure what this is called. is it a window guide? there is just rubber that has chunked off most of my windows.
# 2 window seal
# 3 ???
Re: help on window seals and trim
Like Tony said, wrecking yard is your best bet. I had the same issue with the outer seal(no one knows what it's actually called) which led to a lot of problems with the regulator. I bought a whole door for 40 bucks and tore it down.
Picture 1: I don't know what it's called for the rear door on your car, but on my 1999 Civic's front door it's called Front Door Sash. I guess maybe it's called Rear Door Sash? Pillar Trim?
Picture 2: Window run channel
Picture: Left door Molding Assembly, or, Door-belt Weather Strip, or, window trim, or, Belt Molding
For the window run channel, it looks as though this site has them: https://www.hondapartsnow.com/oem-19...indow_run.html
Does this set maybe contain the molding assembly parts you need for the door?: https://www.autopartswarehouse.com/s...3/H462004.html
smooz EK
11
12-05-2006 12:08 PM
SJR
16
01-29-2006 06:46 PM
sacredc0w69
05-30-2003 03:41 AM
