1997 Civic DX - No start
I did some searching on the forum and did not find anything, but I'm sure this has come up before.
To start, the car was running fine and then I pressure washed the engine bay. I didn't do a very good job of covering the electronics (I know shame on me). Anyway, the car started initially after the wash but after a few second it started to miss fire. I drove it about a mile to my house and now it will not start. The check engine light is on reading a code 72 (misfire in cylinder 2). I changed the spark plugs and check the wires for spark. All spark plug wires are working. I also checked the plugs for the injectors with a test light. They all pulse when the engine in cranked.
Also during cranking, the car sounds normal but every couple seconds it makes a different sound almost like it is putting a stress on the starter motor. Hard to explain.
Looking for ideas of what to try next.
Thanks.
Thanks.
Re: 1997 Civic DX - No start
Disconnect the battery. Remove the distributor cap and unplug the spark wires and all the sensors (be sure to make labels and/or pictures so you can put them back right). Let everything dry out for a couple of days.
CuteAccord
37
01-03-2009 10:41 AM
