D16z6 solid mounts
Re: D16z6 solid mounts
In some cases, "B" series mounts are SIMILAR to "D" series mounts. Coupled with the proper supporting components, they will work in your Civic. The real question is WHY do you want solid mounts ??? There is really no good reason to have them.
Remove stock Z6 mounts, burn out the old rubber. Now "cast" yourself a new solid poly mount reusing the central tube and some liquid polyurethane. Or even a tube of poly window sealant (3M Window adhesive) would do if you want to do it ghetto.
Going to Solid Aluminum mounts is going to be more costly and really have no place on a street car.
DIY VIDYA
DIY VIDYA
Ok thank you guys so much for the help. I decided im just going to try stock mounts since its only the rear mount on the firewall that needs replaced.... on that note, anything i shiuld be aware of when replacing it?
