What engine are these Arp head bolts for
I have head bolts that we're gifted to me and idk what engine they are for and neither did the guy who gave them to me. The only markings it says is m10x1.25 can anyone tell me if they are for my d16z6 or another series engine
O.G. triple O.G.
Re: What engine are these Arp head bolts for
Since you don't know to use a computer, here you go...
https://arp-bolts.com/kits/Make.php?...&_EngModelID=*
OP, you need more information than what you have provided for accurate answers to be offered to you. Although one can deduce that only "D" series head studs are 10mm in width whereas "B", "H", and "K" series head bolts/studs are 11mm in diameter or larger, you are making the assumption that they are HONDA head studs... and ARP makes products for LOTS of different manufacturers. Assuming that they are in fact "D" series studs... you still only have a one in three shot at them being the correct set for your engine since the link provided by NVturbo shows three different part numbers for fourth, fifth, and sixth generation "D" series engines.
You may have to do some measuring of your original head bolts and compare them to the ARP bolts given to you.
I agree with Tony on this one, head studs is something I don’t trust unless they are new, it would be like meeting and having sex with a blind date while being blind folded the whole time. Once that blind fold comes off..... it might be good..... or really bad
