Sudden Death after washing B16a engine
I just recently cleaned my B16a engine and low and behold my car started missing , I replaced the spark plugs, somewhat better, Replaced the plug wires with 8mm and problem solved , Ran perfect, yesterday i went around the block came to stop sign and it just stopped dead, It turns over but will not start, Help.
Re: Sudden Death
No water in distributor .. It has been two weeks since engine wash.. This last problem happened after i solved the missing problem with new plug wires.. Was running perfect.. then just stopped and wouldn't restart.
Re: Sudden Death
I did a spark check (No Fire) I also tested Pressure at fuel filter ( Getting fuel) I will now run to lowes and get a omm tester so i can check the Coil pack as well as the ECM. apparently the new Accel 8MM made the old coil work too hard.. (NKG Plugs) My next Question is would Using a Accel Coil Pack cause more work ? Thanks for all the help..
Re: Sudden Death
Help.. I am at a standstill Get a OEM or Something Excact Fit But a Little Hotter ? I've got 8MM Plug wires, Reg NGK plugs, I don't want more problems if it's not going to make my car run better. Someone that know's please advise.. Thanks
Re: Sudden Death
Well i went with the OEM at Auto Zone $33.00 , Advance wanted $79.00 .. My Delso runs perfect.. well except for maybe the dash lights and tail lights not working that i discovered last night about 1AM driving home from a gig at the brewery .. Ha.. seems i failed to maybe put all the fuses in the back in the correct order while trouble shooting.. Had problems out of my Mesa boogie too. One of those weekends.. Thanks for all your Help..
94_civic_dx
05-18-2005 08:57 PM
