Front passenger squeek help cant figure it out
Old 05-20-2011, 06:02 AM
odie88's Avatar
Default Front passenger squeek help cant figure it out
My front passenger side squeeks when driving.it does it when going over bumps and abrupt movements.took wherl off and moved shock etc wont make the noise.u guys got any ideas?
Old 05-20-2011, 06:12 AM
The Grumpiest
grumblemarc's Avatar
Default Re: Front passenger squeek help cant figure it out
Did you check any of the bushings?
Old 05-20-2011, 06:20 AM
I like to party
2LEM1's Avatar
Christ, the car I just bought is doing this too, but on the driver's side. I thought it was the coilovers at first, but as of yesterday I'm no longer sure. I'm going to tear into it this weekend.
Old 05-20-2011, 06:27 AM
tlarimer's Avatar
I'm thinking bushings not preloaded properly or a wheel bearing
Old 05-20-2011, 07:04 AM
odie88's Avatar
This morning on tge way to work it didnt squeek until I was almost there.the bushings looked good when I looked yesterday.im gunna lube everything up and see if that fixes it if not ill start digging into it
Old 05-22-2011, 08:18 AM
odie88's Avatar
So I tore into it friday night to have no luch at making the squeak disapear.one of my friends said it might be a engine mount or a hanger on my exhaust so im gunna check that probably today.ill keep you guys posted
Old 05-23-2011, 05:38 AM
I like to party
2LEM1's Avatar
I checked mine this weekend too and didn't find anything but a torn boot on my steering rack.
Strange.
Old 06-14-2011, 09:27 PM
odie88's Avatar
mine has to do with the exhaust its where the mid pipe connects there are 2 springs and bolts there that need to be greased up with high temp grease and if possible find high temp rubber washers for in between where the pipe connects should fix ur problem
jdmej814
Suspension & Brakes
09-17-2010 01:11 AM
hard_boiled_EG
05-27-2009 11:30 AM
drift_n_shift
13
07-02-2008 09:54 PM
Mires
10-07-2006 05:53 PM
illagee
10-14-2005 08:38 PM
Quick Reply: Front passenger squeek help cant figure it out
