Back window/ passenger window won't roll down(no blow fuses!) what else could it be?
I just wired up my new radio, and when I went to roll down all the windows in my car, only the drivers side window worked. I've checked all the fuses and none look blown...any other ideas on what this could be?
Re: Back window/ passenger window won't roll down(no blow fuses!) what else could it
looks can be false, grab a spare fuse and replace the ones you checked first because sometimes they look fine but are completely bad
^ bingo.....cleaned it earlier and didn't even realize I had locked it.....I didn't even know there was a window lock!
i have the same issue but the lock button is not push down none of the passenger windows work besides driver side, also try using the key fob but only driver side rolls down, i also notice the clicking sound only when i use the drivers side main switch but no budge, if anyone can help me out that be great, thanks
The Grumpiest
Have you checked fuses?
Have you tried taking off the door panels?
haven't checked the fuses
and have never messed with the door panels
but i will do so tomorrow in the morning, i hope its just a fuse
Okay so just finished checking all the fuses and nothing is blown sounds like the relay works because I can hear it click, anyone else with this problem?
Pull off the door panels and check for voltage at each of the doors that the window doesn't work. It sounds like either blown fuses, power window relay or bad master window switch.
What year are we talking about? 92-95 or 96-00?
Crap sorry guys my mistake I diddnt read the tittle up top I thought this was the tsx section I drive a 06 tsx, once again I apologies for the misunderstanding I'm gonna check with Acurazine but also I'm going to pull off the door panels and check the voltage, fuses are all good
ok so i had the same problem then i googled my problem and this came up, and wow do i feel "slow" i did what grumblemarc said and sure enough that was it was. thanks guys and this is for everyone on here this is by far the best forum
hi guys im new and wanted to pick ur alls brain. i have a 2001 honda civic and the passenger side window wont go up or down nothing. its a 4 door ex both driver side windows roll down and back pass side window rolls down. checked fuses,bought pass side motor and regulator assembly plugged up new one nothing. have power at connector for motor but nothing with either switch
extremely common problem, extremely
TrueUntilDeath.com
09-01-2005 04:17 AM
