code 8, need help
Old May 17, 2011 | 12:22 PM
albanzek3's Avatar
Default code 8, need help
keep throwing code 8 car takes about 4 seconds to start crank is showing perfect timing, replaced the dizzy with the one from my old motor that was in perfect shape and had no codes but i put it in this motor and reset ecu and started it up same thing and only come on when car is running any ideas?
i already seached 100 times people are to lazy to post their resolve
Old May 17, 2011 | 12:32 PM
MR.johnson's Avatar
Default Re: code 8, need help
Originally Posted by EE_Chris
It's a sensor inside the distributor used along with the CYL and CKP sensors to coordinate fueling/timing events.
To troubleshoot, you will need a multimeter.
Basically you need to verify that the TDC sensor resistance is 350-700 ohms (distributor disconnected from main wire harness).
You need to make sure that either of the two TDC sensor wires aren't shorted to ground (with the distributor still disconnected from the main wire harness).
You need to make sure that the wires connecting the TDC sensor to the ECU aren't shorted either to ground (still disconnected).
You need to make sure that with the harness connected, you have the 350-700 ohms at the actual ECU connector. .
googled. took 3 sec. i didnt even have to search 100 times.
Old May 18, 2011 | 06:22 AM
Gomesyx's Avatar
is it obd0 obd1 or obd2 ?
Old May 18, 2011 | 06:23 AM
Gomesyx's Avatar
if its obd0 or obd1 its your tdc sensor ( top dead center )
Old May 18, 2011 | 06:37 AM
MR.johnson's Avatar
so just throw parts at it, or figure out whats wrong first?
Rhood
39
Apr 6, 2017 10:03 AM
Nathan_volcom
Oct 21, 2011 05:49 AM
kwizical
12
Mar 10, 2008 08:05 AM
wsiracerz
Jun 5, 2004 12:31 PM
turboxsi
Jun 10, 2003 03:32 PM
