trying to grenade a motor...how to remove fuel cut?
So my buddys single cam started knocking horrificly, we decided to let it go in a extravagent fashion. Anyway to remove fuel cut so we can just rev it until it shatters?!
Seagull Management
Re: trying to grenade a motor...how to remove fuel cut?
Not unless you run a chipped ecu with no rev limiter. They really aren't all that exciting to see blow up anyway. Also if you throw a rod chances are you will ruin the head, just a heads up in case you planned to reuse it.
u can run it with no oil for a while. as they said its probably not worth ur troubles nor that exciting to see a piece of the block missin from a thrown rod.
we ran a single for 14 min on the rev limiter full of bleach. threw rocks down the TB. nothing. i think the only reason it stopped was the harness melted to the block.
hondacummins
Engine Management and Tuning
12
07-20-2014 08:14 PM
