How to clean iab (intake air bypass)?
As the title says i was wondering if any one knows how to clean the iab on a gs-r motor a write up would be great or any advise would help
thanks in advance
thanks in advance
Re: How to clean iab (intake air bypass)?
Are you referring to IACV or maybe the cold idle valve? Look in th FAQ section on how to clean both. It will help if you have any idle problems. I clean the IACV and eliminated the cold idle valve and my GSR idles great.
if your going to clean the IACV just take the two bolts off, un hook the two hoses. you will see a screen that may need to be cleaned just get some brake cleaner and spray it out let it dry and you should be good!
paul23
12-23-2009 03:39 AM
touandcim
12-18-2008 06:45 PM
