B16 swap into a eg
B16 swap into a eg
Does any one know a website with the full instructions with pictures to install a b16 into a eg. also does the b16 bolt right up into the eg. do i need any additional wiring harnesses. motor mounts. I have a p28 ecu in it right now will that work with a b16. will it allow me to redline at 8500? thanks
Re: B16 swap into a eg (JDMlifestyle)
b16 will directly bolt right into an eg. try http://www.jdmhondaparts.com for motor mounts.
Risky Business
no the p28 wont work with the B16 unless you get it chipped...right now stock it has the fuel maps for a single cam d16z6 and a redline of 7200...i dont suggest using a p28 with your b16 at all unless you have it chipped so it is compatible with DOHC VTEC
Re: (JDMlifestyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlifestyle »</TD></TR><TR><TD CLASS="quote">Y do i need motor mounts if the motor will bolt right up to my eg? hey bauley do u want my ECU</TD></TR></TABLE>
You need B-series mounts, it bolts right up meaning, no cutting or anything required. Civic and Integra share the same chassis.
JohnnyWash1
07-09-2005 06:10 PM
