flywheel or cam gears?
Mr. Badwrench
$200. should i buy flywheel or cam gears?
my block is almost done getting sleeved, the head is all done with 1mm over valves, springs and titanium retainers. this is the question. i have $200. cam gears are easy enough to do, but should i get the flywheel first? basically i had a set of gears and since the car has been down so long i have sold them. should i buy the gears or the flywheel? and if so which do you prefer? just installed a fidanza last night. FYI i have a C.M. Stage 4 still from before. thanks...and have installed CM flywheels before. no experience with the ACT yet.....
Modified by boostedcivicsir at 4:04 AM 5/9/2003
Re: $200. should i buy flywheel or cam gears? (boostedcivicsir)
buy the flywheel... the cam gears can be done later in the car besides the flywheel is like gaining 20hp
