del sol: stopping targa leaks
Old 05-07-2003, 06:22 PM
memphisraines26's Avatar
Default del sol: stopping targa leaks
I'm wondering what can be done to keep the inisde of the car dryer. I know this is a common problem but what can be done? please help i'm tried of the leaky roof in the rain.
Old 05-07-2003, 06:31 PM
solo2slocivic's Avatar
Default Re: del sol: stopping targa leaks (memphisraines26)
contact your local honda dealer about a re-seal kit...its a real pain to do and takes a while...
tech
Old 05-09-2003, 04:58 AM
DRKSol's Avatar
lube.......................... vaseline
Old 05-09-2003, 05:02 AM
New User
Nebula's Avatar
Default Re: del sol: stopping targa leaks (jh)
I have the same problem too, makes me want to get rid of my delsol, I'm thinking of getting nicer seats in my sol, but thats the only thing thats holding me back from doing it.
Old 05-09-2003, 06:00 AM
Phaze2 Mike's Avatar
Default Re: del sol: stopping targa leaks (Nebula)
Id use some lube, or somethign of the sort, I like my sol way to much to sell it cause of a few drips i get in the upper corners. But hell, im not sure id have better seats for fear of water damage. They do sell the re-seal kit if ur up for a nice install.
Old 05-09-2003, 10:34 AM
BERT-O's Avatar
Default Re: del sol: stopping targa leaks (solo2slocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solo2slocivic &raquo;</TD></TR><TR><TD CLASS="quote">contact your local honda dealer about a re-seal kit...its a real pain to do and takes a while...
tech</TD></TR></TABLE>
yep, he's correct.
-Bert
Old 05-09-2003, 11:30 AM
RareSI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by memphisraines26 &raquo;</TD></TR><TR><TD CLASS="quote">I'm wondering what can be done to keep the inisde of the car dryer. I know this is a common problem but what can be done? please help i'm tried of the leaky roof in the rain.</TD></TR></TABLE>
You've got email.
Old 05-09-2003, 11:37 AM
Solracer's Avatar
What year Del Sol Do you have ? The 93-95 Sol's Seals were replaced with a newer version, it used to be covered under a recall but its to long to get them replaced under said reacll, I replaced my Seals mysleft it was not that big of a deal, and my top does not leak at all any more. Also Do not use Vasoline on the seals, it eats them a wal slowy use silcon gresse or buy some seal lub from honda.
Old 05-10-2003, 07:41 PM
Default Re: del sol: stopping targa leaks (Solracer)
thanks for the info. any idea on how much the reseal kit cost and installed? i have a 93 si and need to get a d16z and i have some jamex seats installing and dont want the rain to mess them up. I love the car and want to keep it. thanks
Old 05-10-2003, 08:03 PM
mospeed's Avatar
Go to the parts department, buy some sillicone spray...not LUBE, spray.
Set your targa down on something soft to prevent scratches, and spray all the seals on the car and targa with the spray, repeat this several times, several days in a row.
If it continues to leak, one, search for the leak and see if part of the seals are cracked or plugged.
If option one is your answer, find part, fix and replace.
If problems still persist, contact honda for the seal kit. Expensive and its a pain.
You gotta remember, all targa cars have these issues, del sols have them more than others...
Old 05-10-2003, 09:31 PM
ill phil's Avatar
Default Re: del sol: stopping targa leaks (mospeed)
I say trash them and buy the extra one I got laying around But yeah most of the Del Sol folks I know have the same problem, good to know they have a re-seal kit.
Old 05-10-2003, 09:38 PM
Mag00n's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Solracer &raquo;</TD></TR><TR><TD CLASS="quote"> Also Do not use Vasoline on the seals, it eats them a wal slowy use silcon gresse or buy some seal lub from honda.</TD></TR></TABLE>
silicon grease works good, i have a 94 sol that only had one previous owner, he used the silicon every 3months, it does not leak at ALL. Maybe I'm just lucky, but give that stuff a try. check out http://www.teamdelsol.com for a good how too if you need it
Old 05-11-2003, 05:45 PM
Default Re: del sol: stopping targa leaks (ill phil)
you have an extra seal for a targa top del sol? how much u want for it? thanks i'll try the tips out first then see what happens.
BoostSI
08-31-2006 07:00 PM
LowSlow93Sol
07-04-2006 02:59 PM
turbo eg2
05-21-2005 12:53 AM
jdmeg6civic
02-05-2005 04:58 PM
szwarc28
13
06-01-2004 05:35 PM
Quick Reply: del sol: stopping targa leaks
