torque for upper arm
i was wondering what the torque was for the rear upper arm. I put in two washers. I'm wondering what the torque is for the bolt that holds the upper arm to the body? Thanks
Re: torque for upper arm (minitec)
if it's the 2 bolts 10mm Flange Bolt..they are 29 lb-ft
the flange bolt that is 10x1.25mm that connects upper arm to trailing arm is 40lb-ft.
Good luck with your install..i just found out that courtesy of the previous owner, he seized the bolt, and I can't install my camber kit... now I have to pay a mechanic to blowtorch that bolt off *sigh*.
tazeat
Suspension & Brakes
05-23-2010 06:01 PM
