do tein coilovers rust
1 Post
Re: do tein coilovers rust (eriklxsd)
You already asked this in your other post so why are you making a whole other thread about it?? Re-read the forum rules and guidelines
Teins, unfortunately, rusts....but that's if they are exposed to a bit of moisture. if you're in socal, you should not worry about it too much...
Re: do tein coilovers rust (euclid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by euclid »</TD></TR><TR><TD CLASS="quote">the steel ss's and ha's will certainly rust. the aluminum ra's and re's will not.</TD></TR></TABLE>
Teins do in fact rust, thats why they come with their own spray can of JDM WD-40 ( ). They won't be too bad in So. Cal considering you take good care of them. Spray them down regularly and check them out. Keep them clean and as dry as you can and you should be fine.
Euclid: I'm not sure, but I thought the RA's were not aluminum?
Re: do tein coilovers rust (EKology)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKology »</TD></TR><TR><TD CLASS="quote">Teins do in fact rust, thats why they come with their own spray can of JDM WD-40 ( ). They won't be too bad in So. Cal considering you take good care of them. Spray them down regularly and check them out. Keep them clean and as dry as you can and you should be fine.
Euclid: I'm not sure, but I thought the RA's were not aluminum?</TD></TR></TABLE>
would silicon spray work as well as a rust preventer? or do you just think good ol wd40 will do the trick?
K I O K E N
23
06-14-2004 05:59 AM
