rear seats in a 92 hatch
Re: rear seats in a 92 hatch (teg-your-it)
On the 6th gens There is a bolt in the back and then the two big rubber.....inserts in the front go into the frame, you just pop'em out.
I am assuming the 5th gens are the same.
yes.. there are two clips on each side... basically you have to pull out when you pull up... By pulling out i mean to pull toward the front of the car... it should come out then...
Theres hooks, under the front of the bottom rear seat. When you pull the cushion forward, just wiggle it around, the hook will let go, do one side ata time
Re: rear seats in a 92 hatch (salbaje)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by salbaje »</TD></TR><TR><TD CLASS="quote">there is one bolt in the middle 10 mm when you take that off then yank up on the seat</TD></TR></TABLE> yup thats exactly how you do it ......its located between the bottom part and rear backing close to the middle of the seat on the right side of the center.........dont yank b/c youll probably just end up ruining the seats and tearing them but oh well
SilentHatch
05-07-2006 08:59 AM
Hatch It
03-15-2005 06:01 PM
Sinner
10-18-2004 03:10 PM
