brake question
brake question
I have 95 del sol si w/o abs. I heard that it's rear brake is same as gsr's. How about front? Are they same? If not, is it worth to swap it with gsr's? what about m/c and booster? are they same?
Re: brake question (bearboy80)
I may be incorrect on my Del Sol knowledge but.... I believe only the Del Sol VTEC came with the same suspension (sway bars, brakes, LCA's) as the GSR. I believe the Si came with everything the same as Civic EX's and Si's from the EG time period A true Del Sol person feel free to correct any mis-info. Where's Steve Cockrill with the serious Del Sol info?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bearboy80 »</TD></TR><TR><TD CLASS="quote">I have 95 del sol si w/o abs. I heard that it's rear brake is same as gsr's. How about front? Are they same? If not, is it worth to swap it with gsr's? what about m/c and booster? are they same?</TD></TR></TABLE>
Not tryin to be a smart*ss, but just go outside and look... If you have rear discs, then you have the same rear as a gsr... Put a ruler to your fronts. If they are just over 10" in diameter, then you already have gsr fronts (rotors, anyways, gsr calipers are just slightly larger).
gmcuajo1
06-22-2014 07:23 AM
310HPS2k
10
03-13-2009 05:45 PM
