Climate control Lights... 92 civic CX... I want it to light up
How can i make my climate control, etc. . . light up? which wires should i check and stuff... Errrrrrr..
Re: Climate control Lights... 92 civic CX... I want it to light up (xxh23fuzionxx)
I got it!.......turn your lights on?
No seriously more info would be nice. What exactly is the problem?
What dosent light up? Is it climate control, or all of your interior
lights that are not comming on?
Re: Climate control Lights... 92 civic CX... I want it to light up (d15dude)
hmmm....i have the same issue in my 92 cx. all of the climate control lights worked fine until i added the eg9 gauge cluster, now the climate control lights dont work. anyone know how to fix it?
as in i turb on the lights, It doesnt light up, and same with my Gauge cluster. All fuses are ok.. I just need to know which wire behind the climate control is the Light wire. i dont have a dimmer.. is that a big problem? Because my friends car has a dimmer and everything works fine, except the fact that the climate control in his car doesnt light up too... So if i can tap in a wire to the climate control, which wire should i look at?
If you are running a US underdash harness that came with
a dimmer switch then you will need it for the climate control
to light up. Or if you wanted to be cool and jump the wires
you could take it out. The dimmer switch is like a light switch
and when you take it out the lights turn off.
94preludeguy
10
05-18-2014 10:03 AM
B_Something
05-24-2004 09:06 AM
