'93 DelSol S rear speakers
Did some del sols come with no rear speakers? I noticed the other day that I had no sound coming from the back, so we pulled the panel off to check it out, and there weren't any speakers OR wiring back there. I'm just wondering because the guy I bought the car from was kinda shady.
when i got my s it came with rear speakers. but maybe the previous owner put them in. are the brackets there? just buy some 6.5" speakers from best buy and run the wires up to the audio harness
Re: '93 DelSol S rear speakers
I have a '93 Del Sol s and I found (after some looking) that it did infact have wires for rear speakers but no mounting brakets. I'm currently trying to figure a way of fabricating mounting brackes for 6X8.
all years all models came with 4 speakers. they didn't just put the speaker molding there for fun. i own a 95 S and 93 SI both have four.
did you test fit those rear speakers with the molding? the originals are more oval then round. just so you know.
not all delsol came with radio so why would they put speaker in them ???????and some had dealer installed options like tweeters in the door panels or cd changer in the trunk. also a/c was a dealer installed option
Sol to Sol
Yeah, My 94 Si Sol has speakers, but my Dads 93 Si, DID NOT.
We bought the brackets for his off ebay and craigslist for about $20 each.
The wiring was there, just down in the well.
Speakers were not standard on either the '93 del Sol S or Si.
I'm not even sure that they were an option on the S...
They were more common starting in '94.
ive never heard this come up before in the 5+ years of messing with sols... anyways... my 95 s and 93 si came with them if that helps any
Sol to Sol
Damnit, this was necro'd!
But to add, the speakers we got in my dads car had to be drilled with one hole as it didn't exactly line up the holes. But they were circles, as shown here from Honda...
http://www.hondaautomotiveparts.com/...PEAKER+BRACKET
You may need a better box or amp??? My Kickers used to whoop *** in the trunk. They were pushed by an Autotek 550.2 amp
http://img.photobucket.com/albums/v1...NewRims001.jpg
93-94 S didn't have rear speakers or brackets 93-94 Si and 94 VTEC had rear speakers, 95-97 all models had rear speakers. If you get the brackets out of a model with rear speakers they bolt right up. Just have to add wire in. IIRC the wiring might be there for the stock speaker connectors.
Rear speakers in a del sol is stupid, and useless. Waste of money. When you are at a concert, you do not hear the music from behind you. A properly installed 2 way frontstage, either passive or active, amplified would sound WAY better than the piece of shyt stock, or aftermarket speakers in the front and rear.
If anyone has any questions regarding an audio install in a del sol, PM me. I own one, and know how to build great budget audio systems that will knock your socks off.
Not putting speakers in the rear just allows for more money to be put in the better areas of the system.
I just want to say that I have a 1993 Model S that I just put rear speakers into. It had wiring for rear speakers, but not brackets and no speakers were installed by Honda. I had to get the brackets used from a junkyard. It sounds great now.
dc2doi
Audio / Security / Video
14
02-03-2007 03:57 PM
