rear washer trick...
Hey I just tried the rear camber washer trick last night and it helped out in the toe area ALOT. So, if you're thinking that the trick is just bull sh*t, then think again. Thanks alot to whoever thought up this cheap fix!
Re: rear washer trick... (civickidd99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civickidd99 »</TD></TR><TR><TD CLASS="quote">Hey I just tried the rear camber washer trick last night and it helped out in the toe area ALOT. So, if you're thinking that the trick is just bull sh*t, then think again. Thanks alot to whoever thought up this cheap fix!</TD></TR></TABLE>
Never said it was bullshit, just said it wasn't the safest way to do it.
Re: rear washer trick... (Spade)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spade »</TD></TR><TR><TD CLASS="quote">The possibilty of using "less than high grade" metal.
Stress issues.</TD></TR></TABLE>
also, the contact patch of the control arm to the body is now less.
EK k kay
Suspension & Brakes
05-17-2005 09:39 AM
