Water pump won’t come off.
I took off the (4) 10 mm bolts and the 14-mm alternator bolt but the water pump is stuck on.
I see there are sleeves inside a couple of the 10-mm bolts and I assume they are stuck on those. Do you have to drive this pump on and off? Not much room to swing a hammer. Any suggestions anyone?
I am changing it only because I am changing the timing belt that looks fine too. The pump has no play or anything. If I don't it will go out next month.
Re: (solo2slocivic)
use a screwdriver to pry it off. It has 2 dowels and some Hondabond™ holding it on, it should take little effort. Also I would use Hondabond™ when re-installing it.
Then how do get it back on?
Will the bolts draw it in? Do you hammer it in?
Can I use any gasket sealer? If it has the rubber seal, why does it need a gasket sealant?
Re: Then how do get it back on? (Del Sol Man)
you should actually be able to seat it pretty well by hand and the bolts will do the rest. It does have a rubber seal, but I prefer a little overkill. If you don't want to pay the 14-16bux for hondabond (It is the only sealant I use) Permatex gray is the equivalent.
RacerX3888
02-20-2010 11:46 AM
redboardrdr
10-08-2008 03:54 PM
del_parker
05-14-2003 04:58 PM
