Engine question
Location: Your really lame if you dock my points, WA, 98033
Engine question
99 b16a in 96 hatch using 96 ex harness with kenji obd2-obd1 harness and kenji ecu
drove it around with open header cause the exaust doesnt
bolt up to the header. the car seems to be kinda jumpy, its only throwing one
code for 02, and the idle is at 1500 and it jumps its not a steady idle. any
ideas what it could be?
Modified by ruthlessbucket at 8:46 PM 10/13/2003
Re: Engine question (ruthlessbucket)
i checked under my car and theres a dent in the oil pan and its leaking a few drops of oil from the seal.
motor is acting strange. i was driving home and the tach kept losing power and
raido and all the other stuff inside the car kept going out but the motor stayed on
and it would come back on and go out. it started to bog a bit then the car died, i
think the starter went out. cause it wont start on its own but it does when you
compression start it. the idle is still at 1500. its still only throwing code 1.
one slow coupe
12-24-2005 04:49 PM
