Civic is overheating :(
Re: Civic is overheating :( (middleman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by middleman »</TD></TR><TR><TD CLASS="quote">Water pump? Cooling fans? Is there antifreeze in it?</TD></TR></TABLE> that makes alot of sense, check those.
Re: Civic is overheating :( (TrickHonda77)
See if you bled the cooling system there might be an air bubble in there check headgasket, coolant and all other things.
as a temporary solution....put your heat on the highest setting and put the fan setting on the fastest..this will draw hot air from the engine bay. i know this won't fix the problem but if your friend has to drive the car it will help alleviate the heat.
nonpoint986
17
04-17-2012 03:21 AM
R.coustom
03-20-2011 04:04 PM
