Transmition oil change
Can someone help me where would be that bolt where you take out oil and what size is it. I know it is on left side but I am not sure.
Oh my car is 2000 civic ex AUTO transmition
please help thanks
please help thanks
Re: Transmition oil change (Jaydeep)
not sure about an auto, but for manuals you can skip out on the fill plug. unplug the VSS (vechicle speed sensor) and fill it from the top.
...but i guess you'll want to remove the fill plug anyway to see when it overflows unless measure the amount of fluid you put in... if you get a simple funnel with a flexible hose it is dead easy to use the fill plug, just gets a little messy if you're not careful.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jaydeep »</TD></TR><TR><TD CLASS="quote">Oh my car is 2000 civic ex AUTO transmition
please help thanks</TD></TR></TABLE>
Looks like he said auto to me...in which case I have no idea.
Unless, it's like a lot of the other cars out there, the plug is on the bottom, facing the street.
Does it have a filter too? If so, replace that. That could be inside the pan.
So you'll probably need a new gasket after removing the pan, to get to the filter.
look in the bottem of the tranny. you should see a bolt that looks like it kinda has a flat end and it has i beleive a allen key head. be sure to only use honda atf to fill it up again unless you like a slipping trans.
D Tranny Guru
Re: Transmition oil change (Eee Pee)
EP, the Honda auto trannys have a NON serviceable filter. It can only be replaced upon a complete rebuild.
#1 reason you'll never see a Honda with a automatic in my driveway.
Re: (goodbyegti)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by goodbyegti »</TD></TR><TR><TD CLASS="quote">...but i guess you'll want to remove the fill plug anyway to see when it overflows unless measure the amount of fluid you put in... </TD></TR></TABLE>
No need to measure. B series uses 2.3 quarts. Even 2 will work perfectly fine. D series will be fine on 2.
**** the fill level bolt.
if you have a decent funnel with a flexible hose it is dead easy to use the filler hole, i read a little on here before i did it and everyone was like"yeah its well hard to use the filler hole etc.. use the vss hole" but when i came to do it i had no problems at all..
Peter_404_21
12-30-2008 08:54 PM
