How to? Replace rear hub assembly (wheel bearing) on 92 Si with rear discs?
My wheel bearing noise is getting brutal and finally my part has come in.
What is the steps for installing this? What tools are needed?
1. wheel off
2. Remove caliper and pads
3. axle nut off
4. unscrew the big *** screws (2) on the hub face
5. Pull???
1. wheel off
3. axle nut off
5. Pull???
Re: How to? Replace rear hub assembly (wheel bearing) on 92 Si with rear discs? (92BlackSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92BlackSi »</TD></TR><TR><TD CLASS="quote">5. Pull??? </TD></TR></TABLE>
Uh good luck with that.. the wheel bearing is pressed on so you will need a wheel bearing removal tool.. then after you take it out you will then need to press it on the new hub.. this is something thats not that easy to do w/o the right tools
The rear hub/bearing replacement is one of the easiest things to do.
You have the right procedure, no pulling necessary, the whole hub falls right off.
Just got to remove that big nut in ther center of the rear wheel, the caliper, caliper bracket & disc.
Re: How to? Replace rear hub assembly (7PSI CRX)
exactly what he said but there is a catch. sometimes the inner race stays behind. that's when you ahve to use a cut off tools cut the race half walf way through use a air hammer with chisel bit hit it in the center of the cut. and it will crack the sleeve then remove that and installl. new
New User
Re: How to? Replace rear hub assembly (tvrsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tvrsir »</TD></TR><TR><TD CLASS="quote">exactly what he said but there is a catch. sometimes the inner race stays behind. that's when you ahve to use a cut off tools cut the race half walf way through use a air hammer with chisel bit hit it in the center of the cut. and it will crack the sleeve then remove that and installl. new</TD></TR></TABLE>
thats what happened to mine, i just used an air chissle and put it between the inner race and where it buts up againsts (dunno name) hit it a few times with the air chissle and it popped off.
MarkCayabyab
10-07-2017 11:40 AM
axis11
08-03-2013 05:18 AM
