tranny ok? metal shavings and looseness...
I have this d16z6 tranny that has been sitting for awhile (dont know how long) w/o oil. I was flushing it today with sum 10w30 cos i saw sum metal shavings on the speed sensor. It looked like a lot of metal shavings coming out, little specks, dunno for sure if it was metal but what else would it be? I turned the mainshaft by hand when there was no oil in it, could that have caused these metal shavings?
Also the splines where the driveshafts go into are all loose. I don't mean the splines are damaged, but whatever that piece is you can wiggle around with your finger when you stick it in the driveshaft holes.
D Tranny Guru
Re: tranny ok? metal shavings and looseness... (jaxle)
dead input shaft bearing before being stored.
Bring it to Detroit sometime when I'm up and I'll look at it.
u sure thats it? i guess im going to crack open my tranny today and check it out. ill take sum pics too.
wow this snap ring is a bitch, i got some snapring pliers but i dont see how they are supposed to be used, ugh............. any tips?
and i found this metalic greasy **** where the snapring is:
is it just sum kind of grease or sumthing bad?
Jason C SBB
01-25-2005 10:42 AM
Tyson
04-22-2004 06:20 PM
